Storage optimization
Ente provides several tools to help you optimize your storage usage - both on your devices and in your Ente cloud storage. These are manual tools you can use to clean up and manage your photo library after backup.
Free up device space
Once your photos are safely backed up to Ente, you can free up storage space on your phone by removing local copies. Your photos remain accessible in Ente and can be downloaded anytime you need them.
How to free up space
On mobile (iOS and Android):
Open Settings > Backup > Free up space > Free up device space, review how much space will be freed, and confirm to delete backed-up photos from your device.
The app will delete all photos and videos that have been successfully backed up to Ente, leaving only photos that haven't been backed up yet.
Important notes
After freeing up space:
- Your photos remain in Ente and can be viewed anytime
- Photos are automatically downloaded when you view them in the app
- You may need to clear your device's trash/recently deleted folder to fully reclaim the space
What gets deleted:
- Only photos that are successfully backed up to Ente
- Local copies on your device's internal storage
- Photos from your device's camera roll and other backed-up albums
What stays:
- Photos not yet backed up (they'll be protected from deletion)
- All photos remain in Ente's cloud
- Any photos in albums you haven't selected for backup
Re-downloading photos
When you free up space, photos are removed from your device but stay in Ente. To view a photo:
- Simply open it in the Ente app
- It will be downloaded automatically when you view it
- Downloaded photos use your device storage again
Remove exact duplicates
If you have an existing library with duplicate photos across different albums, you can use the manual deduplication tool to keep only one copy while maintaining your album structure.
How it works
The deduplication tool:
- Scans your entire Ente library for exact duplicate files (same hash)
- Keeps one copy of each unique file
- Replaces duplicates with symlinks in all albums
- Your album structure remains unchanged
- Storage space consumed by duplicates is freed up
Using the deduplication tool
Open Settings > Backup > Free up space > Remove duplicates, review the duplicates found, and confirm to remove them.
Open Settings > Free up space > Deduplicate files, review the duplicates found, and confirm to remove them.
What happens during deduplication
- Exact duplicate files across all albums are identified
- Only one physical copy of each file is retained
- Symlinks (references) are created in all albums that had the duplicate
- Your photos remain visible in all their original albums
- Storage quota is reduced by the space occupied by removed duplicates
Note: This tool only removes exact duplicates (same file hash). For similar but not identical photos, use the "Similar images" feature below.
Remove similar images
Ente provides an ML-powered tool to find and remove photos that are similar but not exactly the same. This is useful if you've taken multiple shots of the same scene and want to keep only the best ones.
How it works
The similar images feature:
- Uses on-device machine learning to find visually similar photos
- Groups similar photos together for review
- Lets you choose which photos to keep and which to delete
- Automatically manages symlinks to maintain album integrity
- Works across all albums in your library
Using the similar images tool
Open Settings > Backup > Free up space > Similar images, review each group of similar photos, choose which to keep and which to delete, and confirm your selections.
The "Similar images" feature is currently only available on mobile. Desktop only supports exact duplicate detection via Settings > Free up space > Deduplicate files.
Album-linked similarity management
When removing similar images, Ente intelligently handles your albums:
- If you delete a photo that exists in multiple albums, Ente keeps it in those albums
- If you delete the only copy of a photo from an album, Ente automatically adds a symlink to one of the kept similar photos
- This ensures no album loses all its photos from a scene
- You can safely prune similar images without worrying about album structure
Prerequisites
The similar images feature requires:
- Machine learning to be enabled (for detecting similar images)
- Photos to be indexed (happens automatically after enabling ML)
- Available on mobile and desktop apps
Learn more about Machine learning.
View large files
If you want to identify which photos and videos are consuming the most storage in your Ente cloud, the large files tool helps you find and review them. This is useful for freeing up storage quota by deleting or managing files you may not need.
How it works
The large files feature:
- Scans your entire Ente library for files larger than 10 MB
- Sorts files by size (largest first)
- Lets you filter by type: All, Photos, or Videos
- Allows you to select and delete files to free up cloud storage
Using the large files tool
Open Settings > Backup > Free up space > Large files to see your largest files sorted by size.
Open Settings > Free up space > Large files to see your largest files sorted by size.
From here you can:
- Review which files are taking up the most space
- Filter by photos or videos using the filter chips at the top
- Select individual files or multiple files
- Delete selected files to free up your Ente storage quota
Deleting files moves them to Trash (recoverable for 30 days) before permanent deletion
What counts as a large file
Files are shown if they:
- Are larger than 10 MB in size
- Have been uploaded to Ente
- Are owned by you (not shared files from others)
Delete suggestions
If you participate in shared albums, album owners or admins may suggest that certain photos be deleted. These suggestions appear in your Delete Suggestions queue for you to review.
What are delete suggestions?
When an album owner or admin wants to help curate a shared album, they can suggest that participants delete specific photos. This is common after group trips or events when someone helps filter out blurry, duplicate, or unwanted shots.
When a suggestion is made:
- The photo is removed from the shared album
- You receive a delete suggestion to review
- You decide whether to delete or keep the photo
Reviewing delete suggestions
Open Settings > Backup > Free up space > Delete suggestions to see photos that have been suggested for deletion.
For each suggestion, you can:
- Accept: Move the photo to Trash (can be recovered within 30 days)
- Reject: Keep the photo and dismiss the suggestion
Why review suggestions?
Accepting suggestions helps you:
- Free up storage space
- Remove photos you might have forgotten about
- Keep your library clean based on feedback from album curators
Rejecting suggestions keeps the photo in your account. The photo was already removed from the shared album when the suggestion was made.
Note: Delete suggestions is currently available on mobile apps only.
Learn more about suggest deletion in the collaboration guide.
Understanding storage in Ente
Cloud storage (your Ente quota):
- This is the storage space in your Ente account
- Counted against your plan's storage limit (e.g., 100 GB, 1 TB)
- Use deduplication and similar images tools to optimize
Device storage (your phone/computer):
- This is the physical storage on your device
- Use "Free up space" to reclaim device storage
- Photos remain in Ente and can be re-downloaded anytime
Trash:
- Items in trash count against your cloud storage quota
- Permanently delete items or empty trash to free up space
- Items are automatically deleted after 30 days
Learn more in deletion feature guide.
Related topics
- Backup overview
- Duplicate detection during backup
- Machine learning
- Deleting photos
- Storage and Plans FAQ
- How can I free up space on my device?
- Will I lose my photos when freeing up device space?
- Can I choose which photos to delete from my device?
- How much space will I free up?
- Will new photos still backup automatically?
- How can I remove duplicate photos?
- What's the difference between duplicates and similar images?
- Does removing duplicates affect automatic duplicate detection?
- How do I review delete suggestions?
