Public links
Ente lets you share your photos via links that anyone can access without an app or account. The contents remain end-to-end encrypted, with decryption keys embedded in the link.
Creating public links
You can create public links in two ways: from an existing album, or by selecting specific photos.
From an album
Share an entire album via a public link:
- Open the album you want to share
- Tap the Share icon
- Select "Create link" or "Share link"
- Tap "Manage link" to configure optional link features like album layout, password protection, link expiry, allow adding photos, etc
- Tap "Copy link" and share it
On web/desktop:
- Open the album
- Click the share icon
- Click "Manage link" to configure optional link features like album layout, password protection, link expiry, allow adding photos, etc
- Click "Copy link" and share it
Quick link (from selected photos)
Create a shareable link without creating an album first:
- Long press to select one or more photos
- Tap "Send link"
- The quick link is created
- Copy and share the link
On web/desktop:
You can create a quick link in any of these ways:
- Right-click a file and select "Send link" from the context menu
- Select multiple files and use the "Send link" action in the top navbar
- Open a file in the viewer and use "Send link" from the viewer menu
How it works: Ente creates a special album behind the scenes and adds your selected photos to it. The link works exactly like a regular public link - recipients see an album with the photos you selected.
Managing quick links:
- View all quick links in the Sharing tab under "Quick links"
- Quick links can be converted to regular albums if needed
- Removing a link doesn't delete the photos
Link features
Public links support powerful customization, security, and control features:
Album layout
Choose how recipients view your public links with these layout options:
Masonry (default): A dynamic grid that adapts to each photo’s size for a seamless layout.
Trip: Explore photos on an interactive map and timeline, perfect for travel and location-based albums.
Grouped: Photos are organized by date, making it easy to browse memories chronologically.
NOTE
Trip layout public links are not supported on custom domains yet. When someone tries to access such a link, they will be redirected to the Trip layout public link on the default albums.ente.io domain. Other layouts will work perfectly on your custom domain.
Password protection
Add a password to your link for an extra layer of security. Recipients must enter the correct password to view photos.
NOTE
Password protection is extra access control, not extra encryption.
Password protection adds server-side access control but does not re-encrypt the files. The files remain encrypted with the same key used for the public link. Password protection prevents unauthorized access by requiring authentication before the server grants access to the encrypted content.
When to use:
- Sharing sensitive content
- Limiting access to a specific group
- Adding security beyond link secrecy
Link expiry
Set an expiration date for your link. After this time, the link automatically stops working.
When to use:
- Temporary event photo sharing
- Time-limited access
- Automatic cleanup of old shares
Options:
- Custom date/time
- Common presets (7 days, 30 days, etc.)
- Can be extended or changed later
Device limits
Limit how many devices can access the link. This prevents the link from being widely forwarded.
How devices are identified:
A "device" is determined by the combination of IP address and browser/app (User-Agent). This means:
- Same browser on the same network = 1 device
- Different browsers on the same device = separate devices
- Same browser from different networks (e.g., home vs mobile data) = separate devices
- Once a device has accessed the link, it can continue accessing it even if the limit is later reached
When to use:
- Sharing with a known small group
- Preventing viral spread of the link
- Adding accountability to sharing
Prevent downloads
Disable the option to download original quality photos. Recipients can still view photos and take screenshots, but can't download the original files.
When to use:
- Protecting professional work
- Watermarked preview sharing
- Limited distribution control
Note: This doesn't prevent screenshots or screen recording, but does make it harder for recipients to get high-quality copies.
Allow joining album
Let people who open the link in their Ente app add the shared album to their account. This is handy when you want other Ente users to keep the album in their Shared tab without sending them individual invites.
How joining works
When creating a public link, by default the Allow joining album option is enabled.
To join a public album, click the "Join album" button, sign in or sign up, and you'll be added to the album.
When you open the link on a mobile which also has the Ente Photos mobile app installed:
- Ideally, you'll be automatically redirected to the app, where you'll see a banner to join the album
- If not automatically redirected, the OS will show an option to reopen the link in the mobile app
- If neither happened, tap the "Join album" button on the page to open the app and join the album
If the Ente Photos mobile app is not installed, click the "Join album" button, sign in or sign up, and you'll be added to the album.
NOTE
When someone joins an album, their email address becomes visible to the album owner and other participants. Disable this option if you need to keep participant identities private while still sharing via a public link.
When disabled, anyone with the link can still view the album in a browser, but they cannot join it from the Ente app.
Tips for recipients
- On iOS, Firefox does not show the option to reopen the link in the mobile app - Safari does.
- The prompt to reopen the link in the app does not work with custom domains; use the default
https://albums.ente.iolink instead.
Allow adding photos (Collect mode)
Enable photo uploads through the link. Anyone with the link can add photos to the album via web browser - no Ente account needed.
When to use:
- Collecting event photos from guests
- Group trip photo gathering
- Wedding or party photo collection
When this option is enabled, the link becomes a "collect link". All photos added through the link count towards your storage quota.
Learn more in the Collaboration guide.
Custom domains
Use your own domain instead of albums.ente.io for your public links.
For example: https://pics.example.org/?t=... instead of https://albums.ente.io/?t=...
Learn more in the Custom domains guide.
Managing links
View all your links
- Go to the Sharing tab (bottom navigation)
- See "Shared albums" and "Quick links" sections
On web/desktop:
- Open the sidebar
- Click "Sharing" to see all shared links
Edit link settings
- Find the link in your sharing list
- Tap/click the three dots menu
- Select "Edit link settings"
- Modify password, expiry, device limits, or other options
- Save changes
Changes apply immediately - anyone accessing the link will see the updated settings.
Delete a link
- Select "Remove link"
- Confirm deletion
Deleting a link makes it immediately inaccessible. The photos in the album remain in your account.
Convert quick link to regular album
Quick links create special albums. You can convert them to regular albums:
- Go to Sharing tab
- Find the quick link under "Quick links"
- Select "Convert to album"
The album becomes a regular album in your Albums tab, and the link continues to work.
How encryption works
Public links are end-to-end encrypted, but with an important caveat:
What's encrypted:
- All photo and video files
- Photo metadata and album information
- Everything is encrypted before leaving your device
The security trade-off:
- Decryption keys are embedded in the link (in the URL fragment after #)
- Anyone with the link can decrypt and view the content
- The keys never reach Ente's servers (URL fragments aren't sent to servers)
For sensitive content:
- Use password protection for an additional security layer
- Set link expiration to limit exposure
- Use device limits to prevent wide sharing
- Consider sharing albums directly with Ente users instead
Implementation details have been documented in our blog post: Building shareable links.
Availability
Public links (including collect links and quick links) are available on all plans, including the free tier. Free plan users can create public links with a device limit of 5.
Free users can:
- Create public links (device limit of 5)
- View public links shared with them
- Add photos to collect links shared with them
- Create and receive shared albums
Paid users can:
- Create public links with no device limit
- Access all other premium features
Related topics
- Collaboration - Collaborate with Ente users or collect photos from anyone
- Custom domains - Use your own domain for public links
- Sharing overview - All sharing methods explained
