Skip to content
Post-installation steps
A list of steps that should be done after installing Ente are described below:
Step 1: Creating first user
The first user to be created will be treated as an admin user by default.
Once Ente is up and running, the Ente Photos web app will be accessible on http://localhost:3000.
Select Don't have an account? to create a new user. Follow the prompts to sign up.
Onboarding screenSign up page
Enter the verification code to complete registration.
This code can be found in the server logs, which should be shown in your terminal where you started the Docker Compose cluster.
If not, access the server logs inside the folder where Compose file resides.
shell
sudo docker compose logs
If running Museum without Docker, the code should be visible in the terminal (stdout).
otp
Step 2: Whitelist admins
  1. Connect to ente_db (the database used for storing data related to Ente).
    shell
    # Change the DB name and DB user name if you use different
    # values.
    # If using Docker
    docker exec -it <postgres-ente-container-name> sh
    psql -U pguser -d ente_db
    # Or when using psql directly
  2. Get the user ID of the first user by running the following PSQL command:
    sql
    SELECT * from users;
  3. Edit internal.admins or internal.admin (if you wish to whitelist only single user) in museum.yaml to add the user ID you wish to whitelist.
    • For multiple admins:
    yaml
    internal:
        admins:
            - <user_id>
    • For single admin:
    yaml
    internal:
        admin: <user_id>
  4. Restart Museum by restarting the cluster
Restart your Compose clusters whenever you make changes
If you have edited the Compose file or configuration file (museum.yaml), make sure to recreate the cluster's containers.
You can do this by the following command:
shell
docker compose down && docker compose up -d
Step 3: Configure application endpoints
You may wish to access some of the applications such as Albums, Share, Paste, Cast, Accounts via your instance's endpoints through the application instead of our production instances.
You can do so by editing the apps section in museum.yaml to use the base endpoints of the corresponding web applications.
yaml
# Replace yourdomain.tld with actual domain
apps:
    public-albums: https://albums.ente.yourdomain.tld
    public-locker: https://share.ente.yourdomain.tld
    public-paste: https://paste.ente.yourdomain.tld
    cast: https://cast.ente.yourdomain.tld
    embed-albums: https://embed.ente.yourdomain.tld
    accounts: https://accounts.ente.yourdomain.tld
If you are using quickstart, note that only Photos and Albums are exposed by default in compose.yaml. Expose or deploy Share / Paste separately before pointing apps.public-locker / apps.public-paste to those URLs.
Step 4: Make it publicly accessible
You may wish to access Ente on public Internet. You can do so by configuring a reverse proxy with software such as Caddy, NGINX, Traefik.
Check out our documentation for more information.
If you do not wish to make it accessible via Internet, we recommend you to use Tailscale for convenience. Alternately, you can use your IP address for accessing the application in your local network, though this poses challenges with respect to object storage (details below).
Understanding IP address challenges with object storage
When accessing Ente using an IP address instead of a domain name, you may encounter issues with file uploads and downloads due to CORS (Cross-Origin Resource Sharing) browser security policies.
The issue: Your browser treats requests between different ports on the same IP as cross-origin requests. For example:
  • Ente web app runs on http://192.168.1.100:3000
  • MinIO object storage runs on http://192.168.1.100:3200
The browser blocks these requests unless CORS is properly configured.
Solutions:
  1. Use a domain name (recommended): Set up a reverse proxy with a domain or use Tailscale to avoid CORS issues entirely.
  2. Configure CORS for your IP: Update the MinIO CORS configuration to include your IP address in AllowedOrigins. You'll need to update this if your IP changes.
  3. Use wildcard CORS (less secure): Configure AllowedOrigins to ["*"] in your object storage CORS settings.
Learn more about configuring CORS for object storage.
Note: This challenge is unrelated to the local storage path configuration (MinIO volumes in compose.yaml). It's specifically about browser security when accessing object storage over the network.
Step 5: Download mobile and desktop app
You can install Ente Photos by following the installation section.
You can also install Ente Auth (if you are planning to use Auth) by following the installation section.
Step 6: Configure apps to use your server
You can modify Ente mobile apps and CLI to connect to your server.
Mobile
Tap the onboarding screen 7 times to modify developer settings. Enter your Ente server's endpoint.
Developer SettingsDeveloper Settings - Server Endpoint
Desktop
Tap 7 times on the onboarding screen to configure the server endpoint to be used.
Setting a custom server on the onboarding screen on desktop or self-hosted web
apps
Step 7: Configure Ente CLI
You can download Ente CLI from here.
Check our documentation on how to use Ente CLI for managing self-hosted instances.
For upgrading
Check out our upgrading documentation for various installation methods.
